Lets say I sketch something and I want it to be mirrored as well, so I'll have two sides of the same sketch. I mirror the sketch and its work, so now when I modify the existing lines and dimensions in the original sketch, the other side (the mirrored one) auto changes as well. But, if I add a line, it wont be mirrored. I wonder if there is a way to actually make one side to be the mirror of the other side, meaning whatever appear in one side of the sketch would also appear (automatically) in the other.
Thank you!
Solved by kacper.suchomski. Go to Solution.
Hi
Nope. The mirror command is a tool that defines dependencies in the area in which it is established. Mirror command is not an operating mode.
Kacper Suchomski
