Hi; how can we create a sketch plane on the projected spline normals?
Can you Attach the file here?
Attach is broken. Click edit reply on your post and you should have an option.
the work plan is not to hared it's by axis solve able the main problem is I can not use the sweep to cutting the circles path sometimes half happen I don't know how I have a clean integrated line. it has an angular circle it's important.
@Anonymous wrote:
thanks for the replay JDMather still I have a problem I don't have attach option.
I showed you how to Attach a file in this thread
Re: (sat) format - Autodesk Community - Inventor
and then you did in fact attach a file.
