- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I want the 1/4" dia. hole on the rail to update it's position when I change the size of the rail. The center of the hole needs to be offset 1/8" from the bottom of the rail and .595" from the top. The problem I'm having is when I create the sketch and want the offset to equal the 14" dimension / 2, that dimension comes up highlighted in RED so for some reason it can't be referenced. It comes up HEIGHT because that's what I named it to reference in the subassembly (not shown here). I don't think this should have anything to do with it but I may be wrong.
The original assembly was rather simple: the rails were say 14" long and the extrusion was contrained in the center of the sketch. Now these rails need to extend further into something else so I used the EXTEND command to make them .595" longer. The reason I did it this way is that the assembly fits into a space that measures 14" x 27".
Should I be going about this in a different way?
Inventor 2021
Windows 10 Professional 64-bit
HP ZBook 17 G6
Processor: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 80 GB
NVIDIA Quadro RTX5000
3D Connexion SpaceMouse Wireless
