I'm trying to re assign XYZ planes after the drawing is complete. I understand changing the view cube etc, but I need to change the sketch itself to match the view cube to help set up machining on our CNC and minimize material waste.
Steve
You might select Move Bodies and then in the dialog box select Rotate.
http://forums.autodesk.com/t5/Autodesk-Inventor/Moving-parts-in-part-environment/td-p/3780746
