Inventor Forum
Need help change the plane.
1 REPLY 1
368 Views, 1 Reply
I am working on a F1 car and need to test it with Falcon. But when I first created the car in Inventor, I put it on the XY plane, and as I see, the flows go on the YZ or other direction but definitely not the XY since I see the flows go from side to side of my car. I even changed the direction on the compass but I still does not work. Please help me on changing the plane orientation in Inventor. However, I heard somebody said we could redefine the sketches and put them in another plane but it seemed does not work on me, it messed up everything. Thanks!
1 REPLY 1
JDMather
Redefine sketch only works in rare cases (where everything is based off first sketch and then part faces.
This same question (in one form or another) has come up 3 times in the past 2 days.
Move Bodies and select the Rotate option in the drop-down.
http://forums.autodesk.com/t5/Autodesk-Inventor/Moving-parts-in-part-environment/td-p/3780746
