- Mute
- Permalink
- Report
Why do lines resize and reorient erratically and illogically when adding constraints to sketches? See the example below. I want to simple constrain the floating line to have it's center point at the end of one of the other lines. When I add a coincident constraint, the line I want to stay fixed is moved and resized and the line I want to move is held fixed. It doesn't matter what order they are selected or any other choice I make. There does not seem to be a logic behind which line moves and which line is fixed.
If I add constraints to the line I want to stay fixed, the software continues to do weird things. The line I want to move changes size or is rotated. Why? This is the worst method of sketching I've ever encountered in 20 years of working with CAD.
There should be a basic logic to the process.
1. The line that is selected second should always stay fixed. Meaning I want to contrain point 1 to point 2, if I select them in that order, then I know which line will move and which will stay.
2. The sketches should not be resized when they are moved. I don't understand why at all this would happen. What sensible logic is there to change the dimensions of the a sketch when it is constrained to another sketch? It is random and stupid.
I can eventually add enough constraints to the first line to get the second line to move the way I want, but this is extremely inefficient and time consuming. It's just a dumb, lazy programming method and I don't understand why. It should be simple and quick to constrain two lines and have them stay the same dimensions and orientation, without first having to add a lot of dimensions and other constraints.
