sketch dimension settings inventor
Teijoh
Message 1 of 10
Teijoh
Is it possible to change sketch dimension size bigger and location to above dimension line like it is possible in solidworks ?
Replies (9)
Message 2 of 10
dgleis
if you got to application options, on the general tab. look for annotation scale and change that from 1 to whatever you like. that should do it.
Message 3 of 10
EdvinTailwind
You can edit any format through the Styles Editor. You can change the Standard styles but also create a style that you only use occasionally and apply manually when needed. In our case, the "Small Text" is standard, but "Big Text" can be used as well (see second image).
(right-click the Style you want as standard in the tree-view and select Active)
Further reading:
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-37BA759A-9336-4536-92DB-62FF84332623
Message 4 of 10
Teijoh
Thank you. I know that. It scales it and also xyz indicator, but is it possible to move above dim line? I think it is not possible.
Message 5 of 10
dgleis
not in the sketch environment that I am aware of, but you can definitely define that in the drawing
Message 6 of 10
kacper.suchomski
Hi
Look this:
Kacper Suchomski
Message 7 of 10
Gabriel_Watson
It is not possible for sketch dimensions. Unless @johnsonshiue has a secret way via the registry perhaps?
Message 8 of 10
Teijoh
Thank you to confirm this. I thought it might be in that way.
Message 9 of 10
johnsonshiue
Hi! Gabriel is right. I am not aware of an option to do that. But you can change the sketch dimension size by using a bigger Annotation Scale (Tools -> App Options -> Another Scale).
Many thanks!
Software Test Engineer
Message 10 of 10
Teijoh
Yes, it came earlier within dgleis answer. Thank you.
