Issue with the projected sketch
robinraju0071
robinraju0071
Community Visitor
Community Visitor
when I move a plane the projected sketch in the plane is not moving with the sketch, what is a solution to this problem?
JDMather
@robinraju0071
Attach file here that exhibits this behavior.
kacper.suchomski
HI
Attach the file and describe which elements cause the problem.
Or record your screen while the problem occurs.
Kacper Suchomski
robinraju0071
Community Visitor
Community Visitor
The model is not currently in my lap, The problem occurred when I moved the
plane containing the sketch and the projection, The sketch moved along the
plane but the projection didn't move along with the sketch and the plane.
johnsonshiue
Hi! The only logical explanation I can come up with is that the change in sketch plane leads to change in sketch geometry type. For example a circle can be projected as an ellipse depending on the sketch plane orientation. Please share the file here. The forum experts can help take a look to understand the behavior better.
Many thanks!
Software Test Engineer
