- Mute
- Permalink
- Report
Hello!
I've been using Fusion 360 for some time, and started using Inventor a couple of weeks ago. While sketching (and extruding/revolving), I've noticed that the behaviour of intersecting profiles differs between both softwares. Namely, in Fusion all lines/curves intersections produce valid profiles, while on Inventor this behaviour seems absent.
The picture below should help illustrate this: On the left, the Fusion sketch can be extruded in the region where the circle and the rectangle intersect, but this can't be done on Inventor (I can select only the full rectagle or the full circle).
I'd very much like to have the same behaviour of Fusion within Inventor, and I assume I'm missing out some very obvious configuration or setting to do so.
Any help would be greatly appreciated,
Best regards.
