Hi all.
I am having problems simulating the elevator control system of an RC airplane.
I have attached the assembly file and all related files, unfortunately all the part names are in Italian, I hope it is not too big a problem, but if so I will rename them all with English names.
As you can see from the picture below the mechanism is very simple: there is a “lever” rotating around a central point and a bar attached to it, the bar is also directly connected to the rear elevator.
Now here's the problem: I've created all the joints and constrains that I deemed necessary, and they all work... at least until I attach the bar to the elevator, as soon as I do that the mechanism won't be able to move anymore.
Do any of you have an idea of what this could be happening? Is it a design flow of the mechanism, a problem with how I set all the joints and constraintso or a problem of Inventor itself?
Thanks in advance.
PS: Sorry for all the eventuals grammatical errors, but I'm not a native speaker.
