Simulation of an RC plane elevators control system not working as expected
Marco_Bertoni
Marco_Bertoni
Hi all.
I am having problems simulating the elevator control system of an RC airplane.
I have attached the assembly file and all related files, unfortunately all the part names are in Italian, I hope it is not too big a problem, but if so I will rename them all with English names.
As you can see from the picture below the mechanism is very simple: there is a “lever” rotating around a central point and a bar attached to it, the bar is also directly connected to the rear elevator.
Now here's the problem: I've created all the joints and constrains that I deemed necessary, and they all work... at least until I attach the bar to the elevator, as soon as I do that the mechanism won't be able to move anymore.
Do any of you have an idea of what this could be happening? Is it a design flow of the mechanism, a problem with how I set all the joints and constraintso or a problem of Inventor itself?
Thanks in advance.
PS: Sorry for all the eventuals grammatical errors, but I'm not a native speaker.
WHolzwarth
There were small changes needed, but now it's moving. Problem may be caused by a 0.09 deg difference in asta_equilibratori.ipt.
Only exchange 4 files in the Zip, others can be re-used.
By the way: Nice-looking parts
Walter Holzwarth
Marco_Bertoni
Thank you very very much for the help, would've never solved the issue it without you, I wish you all the best
