How to I constrain to this weird shape?
eduard.avramPJGGV
eduard.avramPJGGV
Hey there! I'm pretty new to inventor and I need to constrain a screw to only be able to move inside this stadium shaped hole. How could I do this? I've tried some tangential constrains but it's not enough.
kacper.suchomski
Hi
There are many ways.
Transitional, tangential, or mate constraint of construction elements (workplanes and axes).
Kacper Suchomski
Alexander_Chernikov
You can set the minimum and maximum distance from the axis of cylinder to the hole symmetry plane for Mate.
Another option - is to enable the mode "Activate Contact Solver" on the Inspect tab, and set "Contact Set" option by right-clicking for these two parts.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
eduard.avramPJGGV
Thank you so much! This worked perfectly.
