I am using Inventor to illustrate a guide for school students making telescopes. Does anyone know if the render option in Inventor will show the magnifying effect of lenses?
The first image below is from Inventor 2017 Academic Edition and you can just see the glass lenses. The second image is what I am trying to achieve in another CAD program where the lenses are clearer so I know it should be possible.
Maybe I need to alter the render settings?
Many thanks
Tim
Solved by -niels-. Go to Solution.
Solved by blair. Go to Solution.
Solved by I_Forge_KC. Go to Solution.
I don't think so as I've never seen a refractive index for glass in it's properties listed in Inventor.
Dielectrics/caustics are integrated into the Fusion 360 renderer if you'd like to give it a try there.
K. Cornett
Generative Design Consultant / Trainer
Well, I forgot about this!
If you change your appearance library over to the Autodesk Appearance Library and then set the lens to polycarbonate - you get refraction options.
K. Cornett
I'll have to remember that!
Just give the kids a large magnifying glass they can hold for the objective lens they can hold at arms length and a small magnifying glass they can hold close to their eye for the eye-piece.
A simple way to construct a simple refractor telescope.
Too much time spent teaching astronomy at the observatory in my spare time.
It does work (thanks @I_Forge_KC, didn't know this either), but it requires the "realistic" visual style and even then it only works with Ray-tracing enabled:
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Brilliant, it worked using Autodesk materials > Polycarbonate and enabling ray tracing.
Thanks everyone for your suggestions and particularly I_Forge_KC and -niels- for their solutions.
