Inventor Forum
Simplified Part Disappears when edit in assembly
7 REPLIES 7
Message 1 of 8
764 Views, 7 Replies
Hi!
I have an assembly which I simplified to use in another assembly. But whenever i edit this simplified part in the assembly it disappears, the part is usually a surface but when i edit the surface disappears and nothing I´ve tried shows it again. In the model tree (left menu) the part still shows, but when expanding the surface is not there.
After that everytime i try to insert the same part in the assembly it wont show. Even if I open the part individually. The only way for me to see the part again is restarting Inventor, but even that whenever i edit the part the same thing happens.
Anyone knows what causes this? I will attach model if that helps.
Thanks!
Hi!
Thanks!
Labels (3)
7 REPLIES 7
Message 2 of 8
JDMather
JDMather
What is the purpose of the 4 surface bodies?
What is the purpose of this untrimmed surface?
Do you see the same behavior if you install Update 2022.0.1?
Message 3 of 8
I dont know the purpose of those surfaces since i downloaded this model from Rockwell Download catalog, it was originally a .STP
Message 4 of 8
JDMather
JDMather
That changes the problem - some of the geometry is corrupted and will need to be repaired.
Attach the original STEP file here for diagnosis.
Message 5 of 8
in reply to: JDMather
Here is the original STP file. Thanks alot
Message 6 of 8
johnsonshiue
johnsonshiue
Hi! The original STP file from PTC has some bad geometry. Quite a few cylindrical faces have badness (probably tolerance issues). I exported it to IGES with tighter tolerance as a solid. Then import it back. The part body seems to check better.
Try this. Open "1400214-01_10.ipt" and delete the original body. Import attached IGES file. Then try simplification workflow. It should work better.
Many thanks!
Software Test Engineer
Many thanks!
Message 7 of 8
jacqueline.nelson
jacqueline.nelson
Community Visitor
Community Visitor
Good Morning - did anyone ever answer your question about a simplified part disappearing when inserted in another assembly? I could not see any reply's
I am having the same issue - appreciate any response
Cheers
Cheers
Message 8 of 8
johnsonshiue
Hi! I believe it is bad geometry related. Open the simplified part and press Ctrl+F7. Is there any bad body reported?
You may want to run Repair Bodies workflow on the original part (not the simplified one). If you cannot figure out, please share the files here. Forum experts can help take a look.
Many thanks!
Many thanks!
