Showing only a few wires in drawing
I'm creating assembly instructions and I've come across a problem. There are over a dozen wires in single wire harness assembly, but I want to show just some of them in my drawing. However, when I'm in the presentation environment, I can only switch on or off the visibility of the whole assembly. The same applies for the drawing environment. Is there some workaround, or do I have to somehow split the wire assemblies into multiple ones?
Screencast URL: https://knowledge.autodesk.com/community/screencast/53887cad-7479-4c84-a00c-0428fd4e8e74
Best regards,
Adam Schuppler
johnsonshiue
Hi Adam,
I took a quick look at the workflow. I think there is a way to do it but it is not straight forward. If you want, please send me the files directly (johnson.shiue@autodesk.com). I can show you the steps to do it. It involves opening the Harness ipt files and create Design View Reps by turning on and off the surface bodies.
Many thanks!
Software Test Engineer
