I'm creating assembly instructions and I've come across a problem. There are over a dozen wires in single wire harness assembly, but I want to show just some of them in my drawing. However, when I'm in the presentation environment, I can only switch on or off the visibility of the whole assembly. The same applies for the drawing environment. Is there some workaround, or do I have to somehow split the wire assemblies into multiple ones?
Screencast URL: https://knowledge.autodesk.com/community/screencast/53887cad-7479-4c84-a00c-0428fd4e8e74
Best regards,
Adam Schuppler
Hi Adam,
I took a quick look at the workflow. I think there is a way to do it but it is not straight forward. If you want, please send me the files directly (johnson.shiue@autodesk.com). I can show you the steps to do it. It involves opening the Harness ipt files and create Design View Reps by turning on and off the surface bodies.
Many thanks!
