show open dialog slow performance
bradeneuropeArthur
Mentor Mentor
Message 1 of 10
bradeneuropeArthur
It take about a minute to show the opendialog in Inventor the first time you open a file after this it opens normal and directly without delay.
What is the solution for this behavior.
@johnsonshiue
@CGBenner
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Replies (9)
Message 2 of 10
talha.tufan523TD
I think that, its about your subfolders.And libraries. it takes some time to scan them all and write them to ram. trt yo create new project without libraries and subfolders if its normal you can change the file path your subfolders and libraries.
Message 3 of 10
bradeneuropeArthur
Thanks for the answer, but the same I have tested with a clean new project (*.ipj) file.
I have the same slow performance also than.
When I run the Inventor.exe as administrator the performance is normal!
Any further Ideas.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 10
talha.tufan523TD
I think you are using software that checks permissions in managing your local disk. I think that every time inventor wants to access a space on the disk, the permissions are queried. That's why when you run it as admin, the software does not check this situation and everything becomes normal.
Message 5 of 10
bradeneuropeArthur
I have one userprofile that is set as administrator and that is the one I use.
Sounds therefore a bit wierd, isn't it?
How can (your story) this be disabled.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 10
talha.tufan523TD
So, could you try this, ?
Message 7 of 10
bradeneuropeArthur
This is the same as this isn't it?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 10
johnsonshiue
Hi Arthur,
A few things to try. With the same project  file, disable Antivirus tool temporarily. Does it work faster? If not, edit the project file and remove any unused favorite folders or library folders, particularly the ones on a shared network drive.
Please make sure Inventor updates and Vault updates applicable to you are installed.
Clean up %temp%.
Many thanks!
Software Test Engineer
Message 9 of 10
aprajapati3C
Even i am facing the same issue and also the collogues in my office. Same for IN 2023.
I need to check with IT about disabling the anti virus. Other solutions suggested above are not working.
Message 10 of 10
aprajapati3C
My bad.
"Run as administrator" works. But thats a temporary solution. Good to solve it permanently.
