Shortcut L for line does not work
sergio_serena
sergio_serena
In Inventor 2022.2.2 the "L" shortcut for line in sketches does not work. Is it just me?
Replies (11)
James_Willo
Hi Sergio, it's working fine for me.
Check your customise menu:
James W
Inventor UX Designer
johnsonshiue
Hi! Sergio,
As James pointed out in his reply, go to the Customize dialog and make sure "Use multi-character command alias" option is unchecked.
Many thanks!
Software Test Engineer
bradeneuropeArthur
Or use reset all keys!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
sergio_serena
Tried on multiple PCs but the problem still remains. If a change to key "K", for example, everything works fine. How can I check if the shortcut "L" is sued elsewhere?
James_Willo
When you press 'l' does it come up in red in the bar at the bottom of the screen?
In this area?
If so, you need to turn this off:
James W
James_Willo
Here's a better screenshot:
Or:
James W
James_Willo
To see what uses which letter, click on the 'keys' heading which will sort by key. You will then see all the letters grouped together and you can check 'l'
James W
sergio_serena
I think I found the glitch.
By default harness and cables had the same shortcut.
I can't help but wonder, should Inventor warns the user the shortcut is used twice.
SBix26
Inventor should be smart enough to know that the sketch environment is not the same as the C & H environment.  It used to be...
Sam B
Inventor Pro 2022.2.2 | Windows 10 Home 21H2
yaniX2UEG
Well, that isn't the case anymore...  Inventor 2023 here
I'm stuck on this now, and the above mentioned option has been disabled.
DarthBane55
I'm a bit late, just had this issue.  Fixed by deleting all the shortcuts that start with "L", there were a bunch of 2 letters shortcuts starting with "L", so when pressing "L", it was waiting for a 2nd letter it seems.  Been using "L" for ages, never had any issues before 2023!
