Inventor Forum
shell
4 REPLIES 4
357 Views, 4 Replies
shell
Please see extrusion-1 on inventor 2012 .ipt file.
 Can extrusion-1 be shelled between the 2 work planes?
Thank you
IJC
4 REPLIES 4
JDMather
See attached.  You can do a multiple thickness shell if needed. (I turned off the rotated body in the second file for visibility and used multiple thickness rather than splits).
in reply to: JDMather
Thanks JD.The Rev1 was the Shell feature i wanted
JDMather
Do you understand how I got that solution?
(expand the Shell dialog box by clicking the chevron in the lower right corner.)
Yes i got your method
Much appreciated JD
IJC
