Please see extrusion-1 on inventor 2012 .ipt file.
Can extrusion-1 be shelled between the 2 work planes?
Thank you
IJC
See attached. You can do a multiple thickness shell if needed. (I turned off the rotated body in the second file for visibility and used multiple thickness rather than splits).
Do you understand how I got that solution?
(expand the Shell dialog box by clicking the chevron in the lower right corner.)
