sheet metal thickness in IDW Template
alon4
Message 1 of 23
alon4
Found this on a post from 2007:
1 - Open your sheet metal template, click on the parameters button, and check the option to export the Thickness parameter as a custom iproperty
2 (optional) - Check the iproperties of your sheet metal part file and verify the Thickness was added to the Custom tab.
3 - Open your drawing template, go to iproperties dialog, custom tab and add Thickness as a custom TEXT property
4 - In your drawing template, go to Tools > Document Settings > Drawing tab, check the Copy Mode Properties option. Then click on the Properties button and choose the Thickness property in the secondary dialog.
5 - Edit your drawing title block(s) and add the thickness reference by selecting Custom Properties - Drawing Type.
Works great just one problem.
If I change the thickness of my sheet metal part after the views are inserted to my IDW the thickness won't update in the drawing.
Alon
Inventor Product Design Suite Ultimate 2015 SP2
Windows 7 Pro 64-bit
Replies (22)
Message 2 of 23
RobSinglehurst
Add a custom text iproperty to your .ipt template and make it equal to =<SHEET METAL RULE>
This has to be in square brackets and a function symbol will appear after you add it.
In your .idw template add this custom iproperty to your title and then this will be populated with the name of the Sheet Metal Rule from the .ipt
Cheers,
--Rob
Inventor 2024.2
Message 3 of 23
mdavis22569
Can you attach the IPT and IDW ..
Mike
Mike Davis
Message 4 of 23
alon4
When I placed the views the thickness was 3mm and that's OK.
Then I changed the thickness to 2mm but the note in the drawing didn't update.
If I delete the drawing views and insert them again and then insert the note, the thickness in the note will be OK - 2mm.
Alon
Message 5 of 23
RobSinglehurst
Hi Mike,
Please find attached IV2015 files. The ????? are an iproperty in the .ipt that has the CNC Press Brake program number.
Cheers,
--Rob
Inventor 2024.2
Message 6 of 23
mdavis22569
Here ya go ...
I changed the custom property from Drawing to Model ...
Mike Davis
Message 7 of 23
alon4
Mike
Thank you very much but - this can be done only after inserting a view in the IDW drawing.
What I meen is to do this in the IDW Template so it will work for all my drawings.
The problem is that in the IDW Template I don't have the Custom Properties - Model to choose.
Is there a way to do this with the Template? (The thickness in the note will change if I change the IPT thickness)
Thanks again
Alon
Message 8 of 23
RobSinglehurst
Hi Alon,
Did you look at my post?
Cheers,
--Rob
Inventor 2024.2
Message 9 of 23
alon4
Rob,
Thanks and sorry for not responding
Yes I did but I had the same problem. Maybe I did somthing wrong but it worked only for the first time I inserted the view and did not update after changing the thickness.
Alon
Message 10 of 23
RobSinglehurst
Hi Alon,
Are you altering the thickness by picking another Sheet Metal Style? And do you have the "Use Thickness from Rule" ticked under Sheet Metal Defaults? You shouldn't really just alter the Thickness parameter in the Parameters dialog box as the BendRadius etc are all tied in with the sheet thickness under the Sheet Metal Styles.
Cheers,
--Rob
Inventor 2024.2
Message 11 of 23
alon4
The "Use Thickness from Rule" is ticked.
I'm changing the Thickness in the "Sheet Metal Defaults".
It shouldn't matter to all Parameters like "BendRadius" because they all use the Thickness Parameter and change according to it.
Alon
Message 12 of 23
RobSinglehurst
Hi Alon,
With the 2 files I uploaded, if you open them both and then go into the .ipt and select another Sheet Metal Style the name of that style will then appear in the title block in the .idw. I just downloaded and checked them again to make sure.
Cheers,
--Rob
Inventor 2024.2
Message 13 of 23
alon4
OK I see - this works for the specific drawing.
I'm trying to set a Default IDW Template to do this on every drawing.
The problem is that in the IDW Template I don't have the "Custom Properties - Model" to choose
Alon
Message 14 of 23
RobSinglehurst
Hi Alon,
In the .ipt Right Mouse Button on Sheetmetal.ipt and select iProperties, go to the Custom Tab and add a new one (called whatever you want) and for the value type in
=<SHEET METAL RULE>
Then back in the .idw this should then be available to add into the Title block.
Cheers,
--Rob
Inventor 2024.2
Message 15 of 23
alon4
This works for the drawing after a view is inserted.
It does not work for a IDW Template  (if I change the thickness it doesn't update).
 In the IDW Template the only option is "Custom Properties - Drawing"
and not "Custom Properties - Model" which you use after inserting a view.
Alon
Message 16 of 23
RobSinglehurst
Did you go through the steps I described in my post? As this works fine for me.
Cheers,
--Rob
Inventor 2024.2
Message 17 of 23
alon4
Yes I did - and it works in this drawing - but I want the same in the IDW Template
Message 18 of 23
RobSinglehurst
Hi Alon,
If you save that .idw as a template it will work - I have a SheetMetal.idw template for exactly that reason. If the custom iproperty exists in the .ipt it will be picked up in the new .idw created from the template. You will need to place a view initially in the template to populate the Custom Propertys but you can then delete the view and save the template - I'm guessing that is the bit you need.
Cheers,
--Rob
Inventor 2024.2
Message 19 of 23
mdavis22569
Confused ...The note does change if you change the thickness.
I guess I'm confused on exactly what you want.
Mike Davis
Message 20 of 23
mdavis22569
Are you trying to go to custom iproperty in the IDW and change the thickness?  Or the note?
If so it's not possible .. it won't go back to the model and change it.    I ones I uploaded you change the thickness in the IPT, and it will update the note in the IDW and the thickness iproperty.
Mike Davis
