Sheet Metal - Placing few different punches as a group.
Cris-Ideas
Advisor Advisor
Message 1 of 9
Cris-Ideas
Is there a way to place group of punches in one operation?
I have a set of punches that always go together. Currently I need to place them individually.
Is there a way so I can somehow place all of them at once similar like a block?
Cris
Cris,
https://simply.engineering
Replies (8)
Message 2 of 9
kacper.suchomski
Hi
Have you tried creating a new (more complex) iFeature?
Kacper Suchomski
Message 3 of 9
CCarreiras
Hi!
It's not possible... You have to chose only one at once...
I would go with the @kacper.suchomski sugestion, create a new punch with all the operations... if possible...
CCarreiras
Message 4 of 9
Cris-Ideas
In the end I need to have them listed individually.
So creating single I feature does not solve this problem.
Cris
Cris,
Message 5 of 9
Frederick_Law
I make iPart with the final cut out in IV.
Make cluster punch in punch program.
Punch program handle which and how punch layout.
Not IV.
iFeature Punch of door handle and door lock.
Message 6 of 9
Cris-Ideas
I am aware,
But I am not dealing with punch program but meet to generate text file for CNC that does not have any sophisticated software and only accepts an simple text files with simple set of commands in particular syntax.
So what I am actually doing I creating post processor along with data extraction from inventor model.
Cris,
Message 7 of 9
Frederick_Law
Then you'll have to create everything.
Message 8 of 9
johnsonshiue
Hi Cris,
Another workflow to consider is to use Derive instead. You could create the "tools" as part bodies. Then you may derive the tool into the target part. Then you may use Direct Edit -> Body -> Move workflow or Move Bodies command to relocate the tool. Lastly use Combine command to cut the tool.
Though it is more flexible on defining the shape, it could be troublesome documenting it in the drawing (not punchtools).
Many thanks!
Software Test Engineer
Message 9 of 9
Cris-Ideas
@johnsonshiue
This will not work at all as derived geometry is pure geometry only and it does not transfer all feature properties.
When the whole point is to have a punch feature in the end with it's ID, center point, etc.
Cris
Cris,
