Hi, I'm trying to draw this component but I'm finding it a bit tricky. I've tried using contour flange, it only gives me the outline. I've also tried drawing the base of the plate and then adding the flanges but it leaves gaps on the component where there aren't supposed to be gaps. My last resort was using extrusion and then shelling the structure out, it works but I can't get a flat pattern for the component for obvious reasons. I'm unsure on how to use contour roll and I don't know if it's going to help me achieve what I want, if someone could help me draw this component as it is either using contour roll or another that would be very helpful.
p.s I have attached a picture of the component🙃
Thank you
