Inventor Forum
sheet metal part
2 REPLIES 2
236 Views, 2 Replies
sheet metal part
I don't use sheet metal environment often so am requiring some advice and help.
I would most likely make these as 2 separate parts and then assemble BUT could this shape be made with Sheet Metal as a single part?
There would be more folds i presume then how i created
I have attached a 2015 example of what i was looking to make
Cheers
Richard
2 REPLIES 2
CCarreiras
Hi!
In my opinion is easier to produce this in two parts.
One part the "arc part" and the face you have in the model as a second part (welded to the first part at final.)
As a single part, you will not achieve the flat pattern.
CCarreiras
mdavis22569
I would make 2 pieces ...
The top piece would need to be welded on ... you can't roll/fold this as it is
Mike Davis
