Inventor Forum
sheet metal flat pattern problem
22 REPLIES 22
Message 1 of 23
rasprojects
1765 Views, 22 Replies
I have a problem resolving a sheet metal flat pattern situation.
Capture-2 shows the complete corner with on 2 sides a flange with radius from 20mm, and also the corner with a radius from 20mm.
The problem is within the corner with R=20
I modeled it as a solid box and made fillets on the 2 sides and the corner, then i used Shell and got the correct end product. Convert it into a sheet metal part, but its not possible to make a flat pattern from this.
To produce this you need 3 cuts in that corner, so you can make a flat pattern. (Capture-4: see my sketch how it must look like if it would be a flat pattern)
But I’m not able to make these cuts.
This is a problem that i have for more then 2 years and never found a solution.
Is anyone knowing how to solve this?
Best regards,
Richard
22 REPLIES 22
Message 21 of 23
SBix26
in reply to: rasprojects
Inventor will not provide a proper flat pattern in this case.  I was surprised by how close it got, but the spherical corners simply are not flattenable by Inventor.  They cannot be formed by a simple bend or roll operation, and these are the only types of sheet metal forming that can be flat patterned in Inventor.
A "100% solution" will have to be in a different software application.
Sam B
Inventor Pro 2020.1 | Windows 7 SP1
LinkedIn
Message 22 of 23
rasprojects
in reply to: SBix26
Thank you.
Hopefully in the future there will be a solution for it within Inventor.
Again all who participated in this question thanks for your help.
Best regards,
Richard
Message 23 of 23
eseeleyLUVRU
Here is my shot at the sheet metal part.. hope this helps!
