Message 1 of 14
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Edited: swapped acute/optuse in original post. (long day)
I can’t get my head around this one. I’ve tested 2015 and 2016 same results and I don’t think it’s right so hopefully one of you will set me straight and back to where I belong… 😛
In sheet metal if you use flange with orthogonal height datum and the angle is more than 90 (obtuse) then the measurement in the Height Extents is to the highest point on the flange but if the angle is less than 90 (acute) then it’s measured on the lowest point !
I believe that it should always be on the highest point. Now get me sorted please.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
blog.ads-sol.com
