Hey Guys,
First time posting on this forum, I have searched through existing posts which have helped to an extent however I'm still looking for a way to solve this issue.
I have attached a quick part file I did to demonstrate what I'm trying to achieve. I did three separate corners, the contour flange that follows two edges in one feature is what I'm aiming for however the automatic miter doesn't work when performing it over the two separate bodies.
The second corner is an attempted corner seam which seems to work fine apart from the last section of the flange as it doesn't seem I can select all edges at once. (Not sure if this is an appropriate method). I thought maybe the relief cutouts were preventing it so I cut the excess material away, still little success.
The third corner I manually cut the 45 degree miter corners, I believe there is overlapping material, so I might have need to cut away more material/ leave a miter gap for welding.
I hope that makes sense and you guys understand what I'm trying to achieve, any help would be appreciated. I'm open to alternative ideas that I may not be aware of!!!
Thanks Heaps!!!
P.S - Using Inventor 2017
