copying inventor sketch to another work plane with scale factor
Is there a possibility to reduce or enlarge the sketch while pasting on another plane?
Xun.Zhang
Hello @vmmsoke,
First of all, just copy and paste, after that, go to scale command and select all geometries.
Hope it helps!
Xun
JDMather
I recommend that you research Sketch Blocks.
Where do I see the sketch blocks?
johnsonshiue
Hi! You will need to enable Layout tools. In the 2D Sketch environment, right-click on the ribbon -> Show Panels -> check Layout.
Many thanks!
Software Test Engineer
