How to cut a part from a solid using planes
erandauthpala.opita
erandauthpala.opita
Hi all , I have a small problem regarding this solid. I’m not sure actually how to cut the triangular part At the bottom of this cube. I tried using planes and using extrusion but I was out of luck. So I would be really grateful if some of you guys can give me an idea. Thanks!B92ECC57-DDA2-46F9-A043-F4713379FB7E.jpeg
CCarreiras
Hi!
You have several ways you can do this, but the key idea will be, have a proper plane.
You can achieve that work plane with a "3 point plane option", but first, you must have the 3 points.
You can create the points from the Work point tool, or simply with sketches points.
Since I feel you're not very experienced in inventor, I will recommend the sketch method.
Check the video below.
CCarreiras
CCarreiras
Here's the video...
CCarreiras
erandauthpala.opita
Yeah It worked!! Thanks a lot for your help.
