Inventor: Export a wireframe model to obj
Is it possible to export a wireframe model to OBJ? Or export to some format, that i can use in a 3d software like 3DS Max? Thanks
sergio.bertino has edited your subject line (Export a wireframe model to obj) for clarity.
Sergio.Bertino
Autodesk Support
Autodesk Support
Hello @Anonymous,
I see that you are visiting as a pretty new member to the Inventor Forum.
Welcome to the Autodesk Community!
I'm not sure what you mean for "wireframe model", but Inventor and 3DSMax are compatible.
You can either export an Inventor file as .obj, or you can import a native Inventor file directly from 3DSMax.
I hope it helps
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Sergio Bertino
MFG Technical Support Specialist
Sorry, i mean this visual style called wireframe, when i try to export it, it exports a model without this style
You will need to export as OBJ (or STEP etc.) and choose a resolution (ideally not Brep) from the export options menu, then import to 3DSMax and use settings and materials in 3DSMax to render as a wireframe.
Here's a video of how to render wireframe from 3DSMax:
https://www.youtube.com/watch?v=Z_4jBxqTFVY
Sergio.Bertino
Autodesk Support
Autodesk Support
Hi @Anonymous,
How are things going with your wireframe model export?
I think @Anonymous provided a good answer to your question.. (Thanks @Anonymous!! appreciated!)
Could you please let us know if you need additional help?
Sergio Bertino
