We encounter problems with using shared views for first quick review of designs. We use colors to designate certain parts and plate thicknesses. Because of too much reflection and shadow working this becomes quite difficult. Is there setting or way that the surfaces are not reflecting and without shadows?
In your shared view browser, up on the left top is the settings wheel. Click that and select Environment. There are several variations to pick from that change the lighting, background color and reflections. You should be able to (hopefully) find one that makes things easier to look at.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Thank you for your reaction. Yes we have already played with that, but it doesn't give a result we are looking for, there is still too much reflection. (And it doesn't keep the setting when opening the next file, it goes back to default)
This might need to be requested as an enhancement to the viewer. Maybe consider putting an Idea in the Inventor Ideas forum?
Chris Benner
