I want to create a shaft via shaft generator and I want to use a flanges face as reference. I select my placement reference, starting reference and orientation reference. Then I start to put sections I can only go in one direction while adding shaft sections. If I change the orientation all the sections goes to opposite side. But my aim is only put one section to let's say left and continue to add sections to right. I try to explain this in the picture below.
Best Regards,
Volkan
