Set number of parts as parameter and make assembly automatic
Dear CAD  users,
I am a student which is learning to use Inventor, I am fascinated by its parameter design functionality. I would like to ask you a question. Let us  suppose I have a body which is a sampling of many (57) equal parts, regularly alternated.
Of course I could do an assembly where I just past all these parts and connect them together, However, if I need to change the numbers of parts from 57 to 49, I need to remove the parts one by one. As you imagine, this becomes troublesome as larger as the number of parts grows. Is possible to set the number of parts as a parameter, and  then let the program meld them itself (for example, when I connect the first pair)?
Thank for your attention,
Antonio
swalton
Assembly Patterns for equally spaced components.
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-ABC5607F-6128-40C8-BF28-44D918E5803C
Associative Patterns for unequally spaced components.
Use a "frame" part with a sketch-driven pattern as a seed for a feature driven pattern.
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-AFAEC6D0-BBAB-474F-B467-4F3E676BC4AF
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-9B3D1B72-340A-4F3E-9AD1-80E6DDD91ED2
Steve Walton
Inventor 2025
Vault Professional 2025
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Check out this thread and see if any of the files will accomplish what you are looking for using iLogic.
Collection of iLogic models for beginners
Inventor Automatically Space Holes When Dimension Changes
Please select the Accept as Solution button if a post solves your issue or answers your question.
