Autodesk Inventor shows file name or extension is too long
milan5
Message 1 of 31
milan5
Autodesk Inventor shows file name or extension is too long on regular basis.
Don't know what is the exact problem.
I have attached screenshot for reference.
Can any one guide me.
Milan Kantaria
kelly.young has embedded your image for clarity.
Replies (30)
Message 2 of 31
Mark.Lancaster
@milan5
The message is about Firefox..  Nothing about Inventor..  What are you doing that brings up this message?
Mark Lancaster
Message 3 of 31
milan5
Thanks for reply.
Its not about firefox, every time when I use inventor it shows error with different application like firefox, excel, calculator....
Milan Kantaria
Message 4 of 31
Mark.Lancaster
@milan5
Is there any part of your model that's buried deep in folders and have long file names?
Update:  Also are you storing your files under your Windows User Profile?
Mark Lancaster
Message 5 of 31
milan5
File path and name is not that big, it stored in local drive.
Milan Kantaria
Message 6 of 31
mcgyvr
That could easily be registry corruption or even a virus on your computer totally unrelated to Inventor..
How often do you see that message?
Does it only happen when you first start Inventor?
Message 7 of 31
jletcher
 I have been running into this as well.
It shuts down everything and you have to restart computer.
And you are correct it will change the file it has issues with.
Question is this 2018?
If so when you installed 2018 was there a error when you installed?
Message 8 of 31
johnsonshiue
Hi Guys,
I have seen it before. It has something to do with the files stored in %temp%. Some files plus their path exceed 256 characters. Please go to %temp% and clean up as many files as possible.
Many thanks!
Software Test Engineer
Message 9 of 31
milan5
Error came while working on Inventor.
we have formatted whole system and reinstall Inventor but same problem.
Message 10 of 31
milan5
Yes it was Inventor 2018.
then we have format the system and reinstall Inventor but same problem.
and also upgrade Inventor to latest version 2019.
Milan Kantaria
Message 11 of 31
johnsonshiue
Hi Milan,
Have you tried cleaning up %temp% folder? Could you launch File Explorer and go do %temp% and clean up the files there?
Many thanks!
Message 12 of 31
milan5
Hi Johnson,
User have already tried it and one more thing we have noticed if we gave internet to system than it works fine.
Thanks and Regards,
Milan Kantaria
Message 13 of 31
TheeMC
Community Visitor
Community Visitor
I facing same problem as well.
i did install in 8 user PC, but 3 got this issues.
Can you please help to explain what is internet to system?
@milan5wrote:
Hi Johnson,
Thanks and Regards,
Milan Kantaria
Message 14 of 31
milan5
Its just my observation but i don't think this error is related to internet connection.
Milan
Message 15 of 31
milan5
I have already tried it.
Milan
Message 16 of 31
milan5
Anyone have find anything helpful ?
Milan Kantaria
Message 17 of 31
mcgyvr
Milan Kantaria
Ironically someone wrote a knowledge base article using your image stating its still related to a %temp% folder problem..
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Does that error happen when trying to save files?
You haven't posted back into this thread for a few months.. Has this been happening the whole time or did it just start again?
How much space is left on your harddrive?
Have you cleaned out the %TEMP% file ?
Message 18 of 31
jletcher
That don’t work, I empty every morning and still get this when it pleases.
Found it to happen more if browsing in folders with inventor thumbnails going back and forth.
Message 19 of 31
milan5
I tried everything, empty %temp% folder is also not working.
-Milan
Message 20 of 31
milan5
yes same problem, don't know how to resolve this.
Do you have any solutions ?
