I am trying to layout a material handling system that has multiple instances of the same asset (a level conveyor, for example) and want to give them separate names and separate line items on the BOM but haven't found a way to do that. I've renamed the asset instances in the Model Browser and I've tried changing the "Part Number Row Merge Settings" (my default setting was "Enable Row Merge on Part Number Match" is unchecked) but they are still grouped which isn't what I want (I even tried turning the feature on and creating an entry in the "Merge Exclude List" but no luck).
I've also tried to add asset tags to see if that helped to differentiate the parts but, again, no luck.
Anyone else have success changing this?
