Select all occurrences in a presentation file
timdown73
timdown73
Is there a way to select all occurrences in a presentation file?
-Tim U.
Intel(R) Core(TM) i7-10875H CPU @ 2.30GHz 2.30 GHz>Memory: 32.0 GB Ram
Op Sys: Windows 10 professional
johnsonshiue
Hi! Unfortunately the command is only available in Assembly environment, not in Presentation environment. I think it is a great suggestion. I don't see any reason why it should not be. I will work with the project team and see what we can do.
Many thanks!
Software Test Engineer
timdown73
Thank you Johnson. Select all is critical in the Presentation environment. There is an idea in the Idea Station requesting this functionality.
-Tim U.
DRoam
Here's a link to the aforementioned idea: select all occurences in presentation. It only has 5 votes at the moment, so please add your support.
Such a frustrating thing to not have in the Presentation environment.
