Phantom Parts Showing up in Detail and Section Views
Scenario: Existing .iam assembly and drawing file, with various views, details and sections. Several instances of identical phantom assemblies have been added to this assembly. Drawing and BOM update as expected and everything appears fine.
Now, if I was to update a Section View or Detailed View by adjusting the location or size of the cut lines or call-out balloon, these phantom assemblies will show up in the modified detail or section view. Even if they are 10 feet away in the model, the view will now expand to show them and only them. Trying to cycle their Visibility in that view does not work, and cycling Associative on and off in that view doesn't work. Trying to crop the view to exclude the phantom parts in question also doesn't work.
If I place an identical detail or section view, the view appears as expected. I can also now modify this view and the phantom parts do not appear randomly. Although this is a fix, I cannot replace, re-balloon, and re-dimension every section and detail view if I need to adjust that particular view.
I have included a screenshot of a view that I moved off screen to protect some drawing details. The rectangle with fasteners off to the left is the phantom assembly that has been recently added, and despite the fact that it is quite some distance away from the cut lines, it insists on being included in the view.
section view before
section view after
