I have a 3/4 sectioned view rep (Locked) in an assembly. On a drawing, When I select the correct view rep,
- I don't get the save view orientation ( though It show/hide the correct parts). I was expecting this because I had locked in 3D
- I don't get to see the 3/4 section
Any body else experience this?
C1
I think ability to create Design views, Section them & Lock them in the desired orientation is a great feature.
Too bad we cant utilize this in drawings.
I had to use Break out views alternatively.
C1
Autodesk Inventor 2011
I'm also looking for the ability to see an assembly section in a view placed on a drawing using view representations.
The best way I know right now is to literally create a cut in the assembly. The problem is, I have different positions of some components involved. I cannot use any view representations because the cust travels with the part orientation rather than letting the section cut through regardless of orientation.
In the drawing, I need a 3/4 view of a 1/4 section. Can't get there from here using auxiliary views or sections in the drawing.
