Section
Section
Jose_Merino
Message 1 of 12
Section
Jose_Merino
Good Morning, I'm using Inventor 2016, and I have an issue when I do a Section, I send the images, as you can see, in my images I have a pipe with an inlet in the left hand, I make a section almost in the middle of my pipe pointing right side, and I still see the inlet, why, it should disappear, some one have an idea why is this happening and how to fix it?
Replies (11)
Message 2 of 12
jtylerbc
It is probably set to not section "Standard Parts".  If your pipe was placed from Content Center, Inventor would be considering it a Standard Part.
Double-click on the section view, and in the "Drawing View" dialog box, click the "Display Options" tab.  To the right, there is a section labeled as Standard Parts, with two drop-down lists of settings.  You will want to change the setting for Section from Obey Browser to Always.
Alternatively, instead of changing it there, you can find that part under the view in the Browser, and right-click on it.  Go to "Section Participation", and click "Section." This is the setting that "Obey Browser" is referring to.
Message 3 of 12
Are you set up for third angle projection or first angle projection?
Message 4 of 12
Jose_Merino
I try it both options and it continue whit the same thing. I can't change the "Section Participation" to Section.
Thank You.
Message 5 of 12
JDMather
Styles and Standards Editor > change 3rd angle projection.
Hmmm... can make simple example files exhibiting this issue and attach the files here?
Message 6 of 12
Jose_Merino
Sorry and also my pipe is not from the content center.
Message 7 of 12
Jose_Merino
I don't under stand your question. It's a normal section.
Thank You.
Message 8 of 12
In Drawing mode, go to the "Manage" ribbon.  Click on "Styles and Standards", then "Styles Editor".  Upper left corner, click "Standard".  Choose whichever standard you are using.  Choose "view Preferences, then down towards the bottom choose "Third Angle Projection".
Message 9 of 12
Jose_Merino
I'm in "Third Angle Projection".
Thank you.
Message 10 of 12
Jose_Merino
Ok, check this, because for me it's wired, and I don't know why my inventor it's doing it. If I make a Section just in my Pipe (ipt) it do it good, but when I do the same thing with assembly (pipe and brackets) it show me the inlet, I don't what am I doing wrong.
Thank You.
Message 11 of 12
JDMather
Maybe Section Properties is what you want.
Slice or Depth???
Edit:  Oops, I see that you marked the original response as the solution.
Message 12 of 12
Jose_Merino
I use the Section Participation" and click section.
Thank You.
