section
section
bespel
Message 1 of 12
section
bespel
Hi!
Is this possibile in Inventor? How?
Thanks!
Replies (11)
Message 2 of 12
kacper.suchomski
Hi
Currently, this is not possible.
You can report it on Idea Station.
Kacper Suchomski
Message 3 of 12
johnsonshiue
Hi! I think it is doable. This is called Aligned Section View. The section line looks exactly like the image. You will need to create a drawing sketch attached to the target view. Then the section will be aligned like that.
Please try it out. If it does not work, please share the files here. The forum experts and I can help take a further look.
Many thanks!
Software Test Engineer
Message 4 of 12
SBix26
You didn't mention what version of Inventor you're using, but this is my result in 2024.2:
As @johnsonshiue suggested, I simply created the section path as a sketch in the base view, then selected that sketch when prompted by the Section tool.
The drawing you show in your post does not section the ribs, but that is a manual "fudge" that is hard to achieve in Inventor (I think).
Sam B
Inventor Pro 2024.2 | Windows 11 Home 23H2
Message 5 of 12
Alexander_Chernikov
Here, one of the options for modeling parts with a ribs for correct display in the drawing (without hatching) was proposed:
https://www.youtube.com/watch?v=7LeBXOG9nxQ .
To solve the problem, you can create a cavity in the rib with a minimum offset from its contour (for example, 0.001 mm) and the corresponding extrusion size - the mass properties practically do not change.
This can also be done using the iLogic/VBA rule.
The main advantage of the proposed method is that everything is done in the model, and not with the help of additional sketches in the drawing (when changes are made in the model, the drawing is updated automatically).
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 6 of 12
SBix26
Here is the result using @Alexander_Chernikov 's technique:
Sam B
Inventor Pro 2024.2.1 | Windows 11 Home 23H2
Message 7 of 12
89198826955
Can you show a video of the process?
I couldn't reproduce it
inventor2024
Message 8 of 12
kacper.suchomski
@89198826955 start with broken section-line and select broken type section in dialog box on first creation. Next, edit sketch and draw arc.
Kacper Suchomski
Message 9 of 12
SBix26
Your section sketch looks good, but I found that Inventor is quite picky about the sketch and how it is constrained.  My first attempt (message #4) was successful on the first try, which I didn't save after capturing the image.  My second attempt (message #6) was not successful on the first try-- I received a message about the sketch not being valid for a section.  After altering and constraining differently, it was successful.
I don't have time now to learn how to create a video (haven't made one since Screencast's demise), but I'll try later in the day.
Sam B
Message 10 of 12
89198826955
@kacper.suchomski
the attempt was unsuccessful
Message 11 of 12
SBix26
First attempt at video capture since Screencast--
(view in My Videos)
Sam B
Message 12 of 12
89198826955
@SBix26
Thank you
looked
I have an error in dependencies
