Dynamic simulation bug
Roger4562
Roger4562
Hi
I have an issue with dynamic simulation in Inventor 2024 and it appears to be a bug.
I have an assembly (unfortunately I can't upload it as it is a prototype) and it contains a revolution joint. I've set it so that after  1 second it ramps up to a constant 14400 degrees per second until 5 seconds using a cubic ramp. As it revolves, other parts of the assemble enact forces on other parts and most of the time I get the consistent results that I would expect.
However, I've noticed that if I 'tug' too much at the revolution joint in assembly mode, which changes it's start position, then when I run the dynamic simulation then I don't get consistent results. It's as if the simulation is not considering every change of degree of the revolution joint as time progresses and I get 'wonky' results.
The problem is I can't 'reset' this behaviour. Undoing the 'tug' (ctrl z) to got back to the previous start position doesn't help. Restarting Inventor doesn't help. I can't see any function in VBA to reset it that would help. I've even tried changing the advanced settings such as solver precision. Nothing seems to fix it. Once I have this wonky simulation then it remains wonky.
The only work around I have is to go back to a previously saved version of the assembly. So this bug is saved into assembly files.
Any ideas how to 'reset' dynamic simulation?
Roger
JDMather
Set Initial Positions before moving anything (I also set “Home Position” constraints in assembly environment that I suppress before going into Dynamic Simulation.
Best to only simulate through Joint Imposed Motion and not through mouse dragging.
If you are going to impose motion through mouse dragging - be sure to increase number of time steps first and move slowly so as not to overrun the calculations.
Roger4562
Hi
I am using imposed motion as I explain (the cubic ramp) to perform the dynamic simulation. I've also tried altering initial positions in dynamic simulation.
The issue is, I have to perform mouse dragging to tug the parts in the assembly into place as I assemble new prototypes. But I've worked out if I tug too hard then I can not perform an accurate dynamic simulation. So I'm looking for a way to 'reset' dynamic simulation rather than having to go back to previously saved versions, which is time consuming.
Roger
JDMather
Locked Home Positions in Assembly Environment
Initial Positions in Dynamic Simulation Environment
Without actual files - it is difficult to offer specific advice.
I might have some examples in here somewhere...
https://www.youtube.com/playlist?list=PLp5izJt_zvN08mpY4UcYrzJV2N6QOLAIR
https://www.youtube.com/playlist?list=PLp5izJt_zvN0GnwEUFR1zE06nQvDAWxz2
Check in particular the Dancing Robot Practice and Pick and Place Robot Practice videos.
Roger4562
Thanks, I'll take a look. I think as you say the key is to lock everything down as you assemble, I'm just hoping there was a way to 'reset' an assembly in case you haven't done that, I haven't found a way yet, but I'll try adding more locked home positions in assembly and see if that helps
