SECTION VIEW ARROWS POINT AWAY FROM NEW VIEW
chris90
chris90
When creating a new section view, the arrows in the base view point away from the new created section view.  Our QA manager want the arrows to point to the new view.  Is there a setting that I can change so the arrows point to the new view??  Is it part of an ANSI standard that the arrows do not point to the new view?
Thanks!
Chris Breidenbaugh
IV2020
jyager
The arrows are pointing which direction the section is cut, not which direction the section is. If you were able to just flip the arrows it would be wrong, nothing to do with ANSI.
You can just slide your view over to the other side of the main view you cut the section from if it's bothering them that bad.
Jason Yager
Inventor Professional 2025.0.1
Windows 10 Pro 21H2
Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz
32GB RAM
AMD Radeon Pro WX 3200 Series
3D Connexion SpaceMouse Pro
jyager
I often have section of larger assemblies on completely different sheets than the parent view just due to the size/geometry of things. That's the whole point of them being lettered.
I can sympathize with QA requirements but that ones really picking the fly*@#$ out of the pepper lol.
Jason Yager
Windows 10 Pro 21H2
32GB RAM
JDMather
@chris90 wrote:
1.  Is there a setting that I can change so the arrows point to the new view??
2. Is it part of an ANSI standard that the arrows do not point to the new view?
1. Yes - set to First Angle Projection Type in Styles and Standards Editor.
2. Yes - most companies in the USA use Third Angle Projection Type in which case it was shown correctly by standard.
ANSI Standard.pngGiesecke et al - Technical DrawingGiesecke et al - Technical Drawing
I recommend that you pull out your college textbook and refer the manager to ASME/ANSI 3rd Angle Projection standards for Section Views.  I will make significant wager that your company standard is 3rd Angle Projection.
