Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Inventor Forum
Section Participation
17 REPLIES 17
Message 1 of 18
5034 Views, 17 Replies
Shaft should not participate in the section view. Even though I selected the "non" option. I didn’t get it. How to fix it?
17 REPLIES 17
Message 2 of 18
Curtis_Waguespack
Hi fiatnm,
Tools tab  > Options panel  > Document Settings  button > Modeling tab > Participate in Assembly and Drawing Sections setting
See this help page for explanation:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-6A0E43B8-B99D-48ED-A491-D7BE1F36E62B
I hope this helps.
Curtis
Message 3 of 18
mdavis22569
what you have shown is right ... you won't be able to tell on the shaft ...
pull an iso
Mike Davis
Message 4 of 18
in reply to: mdavis22569
Message 5 of 18
mquiles
I have used the solution in other versions of inventor, but in the version of inventor 2023 it does not work. And I have the app fully updated.
Message 6 of 18
in reply to: mquiles
Hi there,
I gave up Autodesk long ago. Now I do not know anything of Autodesk.
Message 7 of 18
SBix26
Can you post a model here that shows the problem?  I'd like to see it for myself.
Sam B
Inventor Pro 2023.2 | Windows 10 Home 21H2
Message 8 of 18
in reply to: SBix26
I have left Autodesk long ago. Now I do not know anything about Autodesk. I have change my profession.
Message 9 of 18
SBix26
@Anonymous I was not addressing you.  Feel free to unsubscribe to this topic (or all topics).  Your comments haven't added anything of value.
Sam B
Message 10 of 18
mquiles
I have succeeded. The indication of no participation in the section had marked it in the wrong place. It is possible. I am sorry. Thanks you.
Message 11 of 18
JaredJanis
I'm having the same issue in Inventor 2023 where selecting None under Section Participation doesn't exclude the part from being sectioned. I see there was an issue that was supposed to be fixed in the Autodesk Inventor 2023.1 Update. I am working with Build: 271, Release: 2023.2.1 - Date: Wed 02/01/2023.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Elementi-spariscon...
@mdavis22569  @SBix26  @mquiles
Message 12 of 18
mdavis22569
What's your pick priority at? Share a screenshot ?
Mike Davis
Message 13 of 18
JaredJanis
Message 14 of 18
JaredJanis
in reply to: JaredJanis
What I'm trying to do is have the parts circled in pink included in the section view but not sectioned. It seems that since they aren't crossed by the section line they are excluded completely.
Message 15 of 18
mdavis22569
that's something different than the issue of 2023.1
need to turn of the participation in the browser tree
https://www.youtube.com/watch?v=wV7XqzjaRIw
Mike Davis
Message 16 of 18
JaredJanis
That is what I have done but it appears to only work on bodies that the section line crosses, bodies completely on the near side of the section line are excluded.
I did come up with a workaround using a derived part to create one solid body while keeping the seams between planes and then having a separate model state for that particular view. It's not ideal, maybe Autodesk will add functionality for this in a future version.
Message 17 of 18
mdavis22569
Hard to say .. without seeing all of the files myself
Mike Davis
Message 18 of 18
JaredJanis
The model files are attached. These have been done as a training exercise by one of my junior designers.
