I have a problem / wish...
If I make a section view and the section line is ending inside the part, Inventor draws new "visible" line to right end of section line (see "now" image).
Is it possible to deside which line inventor uses over there or should this be as idea for development?
Comments, please 🙂
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
I, too, would like some control over this in styles or settings. I typically just hide those lines, because I prefer no line at all.
Sam B
Inventor Professional 2015 SP1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
OK,
Thanks for your replies!
I put this to ideastation...
http://forums.autodesk.com/t5/inventor-ideastation/section-view-boundary/idi-p/5512608
At the very least there should be a jog in the line similar to the jogged dimension line.
