Sculpt error not creating new solid
Message 1 of 14
HI
Have created a 3D sketch and used the surface patch tool to fill in the object with success. The sculpt function will not turn it in to a solid. keeps sending he error message. I have redrawn it from scratch. I have also tried on a different simple geometric shape and the command will not work.
Image of error and file that needs to be converted to solid.
thanks
Nigel
Replies (13)
Message 2 of 14
jhackney1972
I am not sure why Sculpt does not work on this multi-panel surface but I have seen it before.  When it happens I switch to the original method of converting the panels together by using the "Stitch" command.  Use a crossing window to select to be sure you get all of your surfaces and the solid develops just fine.  I have attached you file in Inventor 2008, I hope you can use it.
I find your "Home" view interesting.
John Hackney, Retired
Message 3 of 14
Hi
Thanks, looks great. why cant I export the faces to dxf? Is it because its not a solid?
Need the individual shapes for the CNC 🙂
thx
Message 4 of 14
TheCADWhisperer
How about a "solution that does not require any 3D sketches and is easy to adjust the dimensions (see attached)?
Are you looking for flat panels for each face?
Message 5 of 14
Thank you. Such a powerful program ... continues to amaze me.
Yes looking flat panels on each face.
ThX
Message 6 of 14
TheCADWhisperer
Explain your design intent.
What is the material?
What is the thickness of the material?
Will you cut beveled edges, (and if yes, how?) or are the cut edges perpendicular to the flat?
Message 7 of 14
Hi
Its a reverse bow on a boat (axe hull). Material is 4mm ALU edges are square cut on a Plasma CNC machine
Message 8 of 14
TheCADWhisperer
That is what I thought.
This changes everything.
Your current design does not meet your design intent or real world physical possibility.
Unfortunately I am shutting down just now and will not be able to demonstrate the errors in logic and then how to do it right until tomorrow.
Maybe someone else will come along and help.
This is the key problem statement:
Message 9 of 14
HI,
All ALU plate boats are cut on a CNC and then welded together. The vast majority have hull flair or shape and the edges of the pieces that make up the bow have tension in them. AKA they are pulled together with a 2 tonne comealong and then welded.
I say this as I assume you are talking about he middle panel in the model that is twisted?
NM
Message 10 of 14
johnsonshiue
Hi! Boundary Patch is also considered freeform tool, meaning the geometry may not be unique. In this case, Boundary Patch creates surfaces with gaps. As a result, the Sculpt does not create a solid. You can use Stitch to seal the gaps and turn it into a solid.
Many thanks!
Software Test Engineer
Message 11 of 14
One of the earlier posts had completed the stitching and provided a solid. However you can not export the faces?
NM
Message 12 of 14
johnsonshiue
Hi! Inventor can only make flat pattern of developable faces. Non-developable faces cannot be unfolded yet. The faces on this part are non-developable unfortunately.
Many thanks!
Message 13 of 14
TheCADWhisperer
The edges have a thickness value that is not merged until a weld bead is added to weld the panels together.
Message 14 of 14
TheCADWhisperer
The twisted parts require an extra step using free Autodesk MeshMixer.
