Inventor Forum
Script Error Inventor 2021
3 REPLIES 3
macieksz
748 Views, 3 Replies
When I try to activate Inventor Pro 2021 edu license, an errors occured like in screeshots,
Tags (1)
Labels (4)
3 REPLIES 3
macieksz
in reply to: macieksz
johnsonshiue
Hi! It looks like either the licensing service is corrupted or Inventor fails to connect to the license server via internet. Please go to the following page and update the license service and restart your machine.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Autodesk...
If it still does not help, you may need to reset your license. Go to manage.autodesk.com and check your entitlement -> reset license.
Many thanks!
Software Test Engineer
macieksz
in reply to: johnsonshiue
Hi. It doesn't help, This may be, because actual license did not expired yet? There are still 9 days left.
I am trying to do this, because pop out screen is showing every time I'm running Inventor,
I have old serial number, and new serial number, the old one is still working but as I wrote, it will expire in 9 days, the new serial number is causing the problems mentioned in 1st message.
I will wait till old license expire and then I will try to activate the new one, I am also assuming that maybe old serial will renew automatically.
