@Anonymous
First... What use is the scale on the drawing?
Are you actually using a ruler to measure missing dimensions on the paper?
If not the scale is useless and just remove it and don't show it at all..
Scale is only useful when people are actually using a scale ruler to physically measure the length of undimensioned lines on a drawing..
That is mostly an old/out of date practice..
But again as I wrote above..
If you want to show scale only when there is one part on the sheet and remove it when there is more than one drawing then simply do the following
1)Edit your titleblock and remove any scale reference/prompts.
2)In the template just add regular text with the Initial View Scale parameter (NOT WHILE EDITING THE TITLEBLOCK)
3)Save template
Now when you create a new drawing the initial scale will be filled in automatically.
When you create a sheet with more than one part and you do not want the scale to show simply select that text and press the delete button..
When you are putting that into the titleblock it MUST be there on all sheets..
But if you just put it somewhere on the sheet and NOT in the titleblock you can delete that text if you want by simply clicking on it and deleting it..
There is NO need to manually enter the scale..
In fact please just attach your template file if you cannot understand what I just wrote and I will modify it for you and send it right back to you..
