- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We've discovered a potentially dangerous quirk of the STEP to inventor file format saving mechanism, whereby .ipt or .iam files stored in the same location as the STEP file with identical names to those referenced by the STEP file when it was generated will be automatically overwritten.
For example, creating an assembly of parts in a single folder somerwhere, exporting a STEP file from the assembly to the same location as the original Inventor files, then opening and saving the STEP file. This will overwrite the Inventor file types with "blank" versions of components like you get when importing a STEP file normally (ie. a body exists as before, but all individual features in the tree are lost).
From a usage point of view, we shouldn't ever really be exporting STEP models to the same location as the base models, let alone opening and re-saving them, however it is concerning that the overwriting of existing files happens automatically - that could cost a fair amount of design time!
