Save Inventor 2022 model (ipt) to native Revit file (rfa)
hennadii_k
hennadii_k
There are several topics (this and this) that explain how to save Inventor model to a native Revit file, but unfortunately, no one works for me.
I'm using Inventor Professional 2022 (build: 153) and I do not see 'RFA file' option in a Save As dialog for Export Building Components. Only 'Autodesk Exchange File (*.adsk)' extension is there.
Are there any preconditions to make it possible to save ipt file to rfa? Do I miss some specific module in Inventor?
Appreciate any help.
Gabriel_Watson
EDIT: check if your Inventor Revit interop is installed and registered. More on the article below.
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Unabl...
More on a similar thread below:
https://forums.autodesk.com/t5/inventor-forum/cannot-export-to-rfa-files/td-p/8105338
hennadii_k
Thanks a lot! It helps!
