Cannot export to rfa files
This is the error that inventor launches everytime I try to convert to Revit Family:
"the operation failed to complete successfully"
Have tried everything. Have deleted every autodesk software. Completely delete every autodesk file.
Please help!
Xun.Zhang
It seems data specific problem, would you mind share your data to me via xun.zhang@autodesk.com to have a better understanding of such problem?
By the way, which version are your working on currently?
Thanks!
Xun
EvanGu
It requires Autodesk Revit Interoperability for Inventor 201X, would you please check it is listed in Control Panel->Programs and Features?
Evan Gu
Inventor/Fusion QA Engineer
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Were you able to get your files exported as .RFA?
There are many articles about how to do this, but not many that state the error you are getting.
Inventor to Revit Family File (RFA) Workflow
Export iam to rfa file
CAN YOU SAVE AN INVENTOR ASSEMBLY AS AN RFA FILE?
Can you attach the file you are trying to export or record a screencast showing the behavior as it happens?
Please select the Accept as Solution button if a post solves your issue or answers your question.
